After you change the configuration, you must save the changes on the device. Save the configuration to a file to retain the configuration settings.
When you log out of the EDM interface, a dialog box automatically prompts if you want to save the configuration. If you want to save the configuration, select Yes. If you want to close without saving the configuration, select No. If you no longer see the prompt, clear your browser cache, restart your browser, and then reconnect.
If you do not specify a file name, the system saves the information to the default file.
